NAPA Interchange list
Anything not covered in the categories above.
I got this from a web site... can't remember but I copied it. Not sure if its accurate or reliable:
This information is provided as a good guide. I offer no warrentys on its accuracy. Use at your own risk.
Location Origianal Part # Current Part # Napa # Autozone #
Front Axle hub Seal CV-3665138 CR36200 36220
Front Axle Pinion Seal CV-3653618 CR25970 25970
Front Brake Hoses (2) CV-476719 UBP33676 33676 88249
Transfercase Shaft Seals (4) CV-3659542 CR19992 19992
Universial Joints (6) CV-3660990
210-0178
Rear Right Lug Studs CV-3660032 BK6412583 6412583
Rear Left Lug Studs CV-3665389 BK6412584 6412584
Rear Axle Hub Seal CV-3660089 CR31870 31870
Rear Axle Pinion Seal CV-3653618 CR25970 25970
Winch Drive Shaft U-Joint
210-0153
BRAKES
Master Cylinder compleate CV-605010 Wagner FD-4428 UDP4355
Master Cylinder rebuild kit CV-609070 UP33 MK3630
Brake Light Switch BMD-1320938 ECHSL134 SL134
Front Wheel Cylinder Cups 1 1/4 YT-799299 UP666 666
Rear Wheel Cylinder Cups 1 1/2 DP-5300890 UP725 725
Rear Wheel Cylinder Rebuild CV-604260 UP37 37
Rear Wheel Cylinder Complete DB-5450553 UP3677 3677
Brake Bleader Screws DP-5300892 UP6858 6858
ENGINE
Oil Filter AC-953973 FIL1503 1503
Fuel Filter AC-1595831 FIL3042 3042
Spark Plug AC M8 AC-1557942 ACM8 ACM8
Points DR-1855720 ECHCS763A CS763A
Rotor DR-1883500 ECHRR83 RR83
Distributor Cap DR-1867722 ECHRR95 RR95
Thermostat Housing Gasket CV-828297 THM1038ST 1038
Thermostat 160-180 HR-3108579 THM170 170
Water pump CV-3660335 WP58125 58125
Lower Radiator Hose CV3677181 NBH8632 708
Upper Radiator Hose CV-3677182 NBH8632 8632
Radiator Drain Cock CV-3664180 BK6051276 145
ELECTRICAL
6V bulb for Black out GM142303(No.63) LMP63 63
