Well the first of two Lenovo laptops arrived. $50 delivered for an I5 4Gb laptop. I had to add an HDD (I seem to have quite the collection of spare parts... no, I'm not a hoarder, honest) and buy an HDD tray ($2) to make it look pretty. I reused a copy of Win 7 that was then upgraded for free to Win10. Win10 kicks ass.
- lp1.JPG (106.9 KiB) Viewed 6004 times
There are dozens of these laptops available on ebay. One caveat to this specific laptop is that the 'lowjack' BIOS was enabled. It doesn't effect operation, and one call to the company should get the laptop out of the 'lowjack' system. Just a caution, READ THE AUCTION DESCRIPTION.
So then I went to Sweetwater and bought two things. EZDrummer2 and a Beheringer audio interface. Both were on sale because of Black Friday, so I saved about $100 by buying now. I'm sure there will be another sale at the end of the year, though.
- ez2.JPG (85.15 KiB) Viewed 6004 times
- ez3.JPG (50.91 KiB) Viewed 6004 times
This added $160ish to the cost. The EZDrummer2 software is basically recorded drum sounds that the Crimson drum module will trigger with MIDI data over USB and the UMC202HD is a 24-bit/192kHz AD/DA converter. Basically its a really fast sound card. The UMC202HD can record audio and send to a DAW (Digital Audio Workstation) for processing AND also take the digital audio from a DAW or EZDrummer and convert it back to analog audio for playback via a stereo/speakers. The reason I bought the audio interface is that I didn't think the laptops sound card would be fast enough to keep latency low enough. But by using the ASIO4ALL driver my $50 laptop has 1.5ms latency. That means when I trigger a drum pad, the signal goes to the drum module, to the laptop, into EZDrummer2 and out the sound card in 1.5ms. Almost instantly!!!!! FOR A $50 LAPTOP!!!!!!!! My PC can only gets down to 6.5ms!!! Both are incredibly good times, btw. Another bonus is that I I now have a semi-professional level recording device for dubbing videos, if I so choose. I can also plug in a guitar and use amp modelling apps like Reaper and not have to buy individual amps or effects pedals.. simply get a plugin for the DAW and POW! Muh tones! The UMC202HD comes with a license for Tracktion DAW, which means I won't have to buy a DAW, either.
I am extremely happy with my setup. It sounds FANTASTIC. Drum module sounds have to be optimized to reduce storage space and the CPU in the modules doesn't really have the HP for a lot of sound processing. EZDrummer2 opens up a LOT of those option. Yeah, I now have a laptop chained to my drum set... but oh well. For home use its absolutely not a problem. PLUS I can run HDMI to my TV and use it to stream videos/movies etc. It's a LOT more convenient than using the current method I have with my PC.
