Brent Mullins is ripping off my decals.. POORLY
Well it looks like imitation is the sincerest form of flattery:
Brent Mullins is selling a poor quality copy of my decals. NOT WATER SLIP. and 50%+ more expensive.
The FUNNY PART is that you DON'T EVEN GET THE RIGHT DECALS!!!! You need TWO oil pan decals. So to do an engine you'll need two sheets at over $60 HAHAHAHAHA
I have not had the interest to reorder the PROPER water slip decals. But I do plans to redo them and also add in the Hydrovac and tire jack decals. Will be expensive. The printer raised the minimum order to 500 sheets and at $2-3 per sheet that's a ton of cash to tie up in decals.
If you want ORIGINAL WATER SLIP decals email me. I have everything EXCEPT the oil pan decals. Proper decals at less than half the price.
Re: Brent Mullins is ripping off my decals.. POORLY
Is that why the pics are gone on your decals page?
No.
I don't have enough of the oil sump caution decals to make a set.
A new round of decals is in the works and I am adding CCKW Hydrovac decals.
Artwork and color is in process, but because of the size of the sheet its much more than the first run.
I really have to put some time into the site again.
