Poroper coil?
Posted: Thu Aug 02, 2012 1:04 pm
The TM shows this:
This is what I bought off ebay:
The metal stamping on the positive pole can be removed. I have two actually. One has a smooth lacquer surface the other has a textured surface. Would this be an early/late thing? The smooth painted coil also has a decal AMPCO Products. The textured one has no decal.
It looks close.
Re: Poroper coil?
Posted: Thu Aug 02, 2012 2:32 pm
Well, define "proper". I presume that's what you meant?? The parts manual lists it as a DR1115149, indicating it was mfg by Delco Remy. It should have a white porcelain bottom (see page 144 and again on page 164 in the same manual you looked at). Not to say others won't work!
Re: Poroper coil?
Posted: Thu Aug 02, 2012 5:34 pm
I can make the porcelain white. :D
I did see one with a white tip, but it was cracked.
